STEVAL-ASTRA1B - Teseo-LIV3F GNSS Not working
Hello
FP-ATR-ASTRA1  - platform STEVAL-ASTRA1B, Teseo-LIV3F GNSS module
Outdoor GPS  not working, Requesting  help to fix this.
latitude: 0.0, longitude: 0.0,  altitude: 100.0
Thank You
Sudhir
Please update ASTRA1B to the latest version 2.0.0
https://www.st.com/en/embedded-software/fp-atr-astra1.html
Secondly, are you testing GPS with clear view of the sky?
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
Yes testing GPS outside with clear sky view (Line of sight).
Will Update and check again.
Thank You
Suds
I wanted to check if you were able to see GPS signals after updating the ASTRA1B firmware to the latest release?
Thanks,
George
Visitor II
December 6, 2024
Hye GalaxyQuest.
My team also have same issue on this. We would like to try updating ASTRA-1B firmware. We download the firmware zip file from the STEVAL-ASTRA1B product page. Under tools & software tab and under MCU and MPU embedded software section. I download version 2.0.1
After for quite sometimes searching for the firmware. I stumble upon this binaries folder. Which I believe the firmware for STEVAL-ASTRA1B. Is this the firmware that i suppose to upload to STEVAL-ASTRA1B?
This is the firmware binary that needs to be programmed.
en.fp-atr-astra1\Projects\STEVAL-ASTRA1B\Applications\AssetTracking\Binaries
Thanks,
George
Visitor II
December 10, 2024
Hii GalaxyQuest,
regarding an update for Steval -Astra1b firmware, which board should I update the firmware on STM32WB5MMG module or the STM32WL55JC module? Plus, which STM32 software is preferred to update the firmware?
thanks,
Izzul.
