For the MLC, how can the IMU work independently from the microcontroller and wake it up with an interrupt?
Evelina CAMILLERI
[webinar - Program decision trees in sensors with a Machine Learning Core]
Evelina CAMILLERI
Once the MLC is configured to run on the device, the MLC keeps generating results (every MLC ODR) on the MLCx_SRC registers. The device generates an interrupt signal when a change of result occurs in one of these registers, in this way the microcontroller can be waken up to read the new result generated by the MLC.
