Error analysing LSTM model using X-Cube-AI: ""NOT IMPLEMENTED: Order of dimensions of input cannot be interpreted""
  • December 12, 2024
  • 7 replies
  • 2968 views
As stated, I have problem analyzing the ONNX model ported from a pytorch model. The code of the model is simple as follows:
class LSTM(nn.Module):
 def __init__(self, input_size, hidden_size, num_layers, num_output=1):
 super(LSTM, self).__init__()
 self.num_layers = num_layers
 self.input_size = input_size
 self.hidden_size = hidden_size
 self.num_output = num_output
 self.lstm = nn.LSTM(input_size=input_size, hidden_size=hidden_size,
 num_layers=num_layers, batch_first=True)
 self.fc = nn.Linear(hidden_size, num_output)
 def forward(self, x, device='cuda'):
 ula, (h_out, _) = self.lstm(x)
 out = self.fc(h_out[-1])
 return out
 Netron vis:
I will really appreciate any advice or workarounds. Thank you!
Best answer by Julian E.
Hi everyone,
I did some test on my side and we currently only support LSTM with 1 hidden size and 1 layer. Something like:
import torch
import torch.nn as nn
# Simple lstm that works
 num_layers=num_layers, batch_first=True, bidirectional=False)
 return out
# If not 1 : error
# other parameter we can put anything
input_size = 10
hidden_size = 1
num_layers = 1
num_output = 10
model = LSTM(input_size, hidden_size, num_layers, num_output)
model.eval()
dummy_input = torch.randn(1, 128, input_size)
onnx_file_path = "simple_lstml.onnx"
torch.onnx.export(model, dummy_input, onnx_file_path,
 input_names=['input'], output_names=['output'])
I tried to stack multiple LSTM but I had no success.
I am asking for more information, I will keep you updated
Have a good day,
Julian
Julian E.
Hello @Lemanoise,
Can you attach your onnx model in a .zip file please?
In the meantime, make sure you follow the conditions described in the ONNX Toolbox documentation concerning the LSTM:
LSTM
Computes a multi-layer long short-term memory (LSTM) RNN to an input sequence (batch=1, timesteps, features)
  • category: recurrent layer
  • input data types: float32
  • output data types: float32
Specific constraints/recommendations:
  • stateless mode support only
  • fused activation: sigmoid
  • fused recurrent activation: sigmoid
  • return_state not supported
  • Only 1 input is allowed for LSTM; the others should be constant and placed into the initializers
  • layout=1 attribute is not supported
https://stedgeai-dc.st.com/assets/embedded-docs/supported_ops_onnx.html
Have a good day,
Julian
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
LemanoiseAuthor
Yeah sure, here is the onnx model. Thank you for your advice and I'll look into it as well.
December 16, 2024
Hello,I have the same question.Do you slove this question?
LemanoiseAuthor
No not yet, I hope ST staffs will check my model and give us further guidance.
Julian E.
Julian E.Best answer
Hi everyone,
import torch
 return out
# If not 1 : error
input_size = 10
hidden_size = 1
num_layers = 1
num_output = 10
model.eval()
Have a good day,
Julian
LemanoiseAuthor
Thank you! I have tried the one-layer case and it succeeded. Please keep sharing further information on multi-layer case if any :)
Julian E.
Hello  @Lemanoise ,
Using tensorflow, I could use multiple LSTM one after the other (which I did not succeed to do with pytorch).
It may be useful for you:
import tensorflow as tf
from tensorflow.keras.models import Model
from tensorflow.keras.layers import Input, LSTM, Dense
input_layer = Input(shape=(100, 2), batch_size=1)
lstm1= LSTM(32, activation='relu', stateful=True,return_sequences=True)(input_layer)
lstm2 = LSTM(32, activation='relu', stateful=True,return_sequences=True)(lstm1)
output_layer = Dense(units=3, activation='linear')(lstm2)
# Create the model
model = Model(inputs=input_layer, outputs=output_layer)
# Print the model summary
model.summary()
# Compile the model
model.compile(optimizer='adam', loss='mean_squared_error')
model.save('tf_lstm.h5')
Be careful to follow these instructions while using it:
https://stedgeai-dc.st.com/assets/embedded-docs/keras_lstm_stateful.html
Have a good day,
Julian
LemanoiseAuthor
Thank you very much!
Julian E.
Hello @Lemanoise,
I should know more about how to use LSTM properly with ST Edge AI Core on the start of next year.
But for the moment I managed to use more than one hidden size with pytorch by not using the batch_first option:
import torch
 num_layers=num_layers, batch_first=False)
 return out
# If not 1 : error
# other we can put anything
input_size = 10
hidden_size = 10
num_layers = 1
num_output = 10
model.eval()
dummy_input = torch.randn(1, 128, input_size) # Batch size 1, Sequence length 128, Input size 10
It may help you
Have a good day,
Julian
