Jf.1
Can I add multiple models to X-cube ai that would have multiple outputs?
I would like to ask whether it is possible to put multiple models into an MCU using x-cube ai. The first model would generate one output which will be one of the inputs for another model with 13 inputs and 3 outputs.
If you could provide steps as to how to achieve this, it would also be very helpful.
Kind regards,
Jona
    Gln
    GlnBest answer
    Hello @Jona,
    Yes this is possible. You will have to write your own code to assign the outputs of the first model to the inputs of the second model. Reshape and/or transform if necessary.
    Adding multiple models to X-CUBE-AI is described in the User Manual, section 4.7 Adding a new DL model:
    https://www.st.com/resource/en/user_manual/dm00570145-getting-started-with-x-cube-ai-expansion-package-for-artificial-intelligence-ai-stmicroelectronics.pdf
    Guillaume
    Gln
    GlnBest answer
    Hello @Jona,
    Guillaume
    Jf.1
    Jf.1Author
    Hi Guillaume,
    Thank you for your reply, I'd also like to ask if models with multiple outputs can also be added in x-cube ai?
    Kind regards,
    Jona
