TheOtherMarcus
Visitor II
September 23, 2021
On SPC563xx, are there any known problems with writing to Flash and runing code, i.e. interrupts, at the same time?
  • September 23, 2021
  • 1 reply
  • 820 views
I run code from Low and Mid address space and write to High address space in Flash C90LC. If I have interrupts enabled during write, the MCU frequently locks up.
    Best answer by Erwan YVIN
    Hello Marcus ,
    no issue has been noticed
    Have you checked SPC563Mxx_RLA Flash Test Application for Discovery in SPC5Studio Tools Suite or RM0015 ?
     /*==================== Lock to Protect Shadow Row ====================*/
     returnCode = pSetLock( &ssdConfig, LOCK_SHADOW_PRIMARY, 1, FLASH_LMLR_PASSWORD );
     if ( C90FL_OK != returnCode )
     ErrorTrap(returnCode);
     returnCode = pSetLock( &ssdConfig, LOCK_SHADOW_SECONDARY, 1, FLASH_SLMLR_PASSWORD );
     /*====== Unlock all blocks in low address space ======*/
     returnCode = pGetLock( &ssdConfig, LOCK_LOW_PRIMARY, &blkLockEnabled, &blkLockState );
     returnCode = pSetLock( &ssdConfig, LOCK_LOW_PRIMARY, (blkLockState & 0xFFFFFF00), FLASH_LMLR_PASSWORD);
     	returnCode = pGetLock( &ssdConfig, LOCK_LOW_SECONDARY, &blkLockEnabled, &blkLockState );
     returnCode = pSetLock( &ssdConfig, LOCK_LOW_SECONDARY, (blkLockState & 0xFFFFFF00), FLASH_SLMLR_PASSWORD);
    Best Regards
    Erwan
    1 reply
    Erwan YVIN
    Erwan YVINBest answer
    Hello Marcus ,
    Best Regards
    Erwan
