PIndr.2
I want to know how to change the white theme to a dark theme in SPC5Studio.
Is it possible to change the white theme to a dark theme in SPC5Studio?
    Peter BENSCH
    This should be possible, please check and try this thread.
    Hope that helps?
    /Peter
    PIndr.2
    PIndr.2Author
    Dear Peter,
    Can you please give me directions to change the dark theme?
    Pasindu
    Peter BENSCH
    OK, maybe the information at the link provided is not sufficient.
    In fact you just need to install Devstyle, which has been discussed very often here in the Community - just search for Devstyle.
    Devstyle requires the installation of Oxygen:
    Then try installing DevStyle and check if it installs fine: Help > Eclipse Marketplace --> Devstyle
    Good luck!
    /Peter
