GKulk
Visitor II
May 29, 2019
I am using SPC560B60L3 micro controller. RTC interrupt is not setting as per the desired time out value
  • May 29, 2019
  • 1 reply
  • 690 views
Below is the code snippet,
   RTCModule->RTCC.B.RTCIE = RTC_DISABLE;
   RTCModule->RTCC.B.CNTEN = RTC_DISABLE;
   RTCModule->RTCC.B.DIV512EN = RTC_DISABLE;
   RTCModule->RTCC.B.DIV32EN = RTC_DISABLE;
   u32RTCcount = (u32Seconds * 64000) >> 10;
   RTCModule->RTCC.B.RTCVAL = u32RTCcount;
   RTCModule->RTCC.B.RTCIE = RTC_ENABLE;
   RTCModule->RTCC.B.CNTEN = RTC_ENABLE;
Here u32Seconds  is 600. After programming this, I expect RTCCNT should set the interrupt after 600 counts. But interrupt is occurring at 517 counts.
    1 reply
    Erwan YVIN
    Hello Gururaj ,
    Did you solve your issue ?
    What is the value of RTCCNT when the interrtupr is occuring
    Best regards
    Erwan
