aurelien23
CAN / CAN-Open / UART Bootloader?
  • June 26, 2015
  • 3 replies
  • 1230 views
Posted on June 26, 2015 at 16:50
I can't find any application note regarding bootloader on SPC56. I'm looking for CAN or CAN-Open or even uart bootlader to reflash my SPC56EL60. Any advise is welcome!
Thank you.
    Erwan YVIN
    Posted on June 29, 2015 at 16:24
    Hello Aurélien ,
    Did you check the chapter 10 in the reference manual ?
    Boot Assist Module (BAM)
    Best Regards
                          Erwan
    saswatkd
    Posted on July 22, 2015 at 14:09
    You will find the required info in Chapter 6 Microcontroller Boot in ''RM0037
    Reference manual''
    Best Regards,
    Saswat
    aurelien23
    Posted on January 09, 2017 at 09:14
    There is a solution using LINflex: search for SPC5-Flasher. V2.5+ supports all families and clock combinations.
