AEK_POW_BMS63EN Fault_L_line_status is always 1
- 6 replies
- 3466 views
Dear Community members,
I have connected 2 node in ring configuration, and working on an custom pcb for BMS.
In registers Faults1, Fault_L_line_status is always 1, while all other fields of Faults1 and Faults2 registers are 0.
Also the OVRLATCH is not detected.
What could be cause to set 'Fault_L_line_status' 1 and where could I check to diagnose.
screenshot for expression view is added for reference for both nodes 1 and 2.
bitBuddy
