Jun 4, 2025 12:12 PM UTC
Unable to update firmware
I want to use stm32H5 series microcontroller and I am trying to write from STlink... I can access the microcontroller by SWD (I can check Option Byte), but I can't write. I can write to the USART via the bootloader with TrustZone disabled, but... I would appreciate it if you could provide me with some information about this.
Maryem
Jun 4, 2025 1:07 PM UTC
Hello @Satoshi1 and welcome to the Community,
Could you please clarify what you mean by "you can't write"? Did you face any specific errors during erasing, programming, ...? Additionally, which version of STM32CubeProgrammer are you using?
Sharing logs could be helpful to understand the issue better.
Thank you,
Maryem.
Satoshi1Author
Jun 5, 2025 12:36 AM UTC
Thank you for your reply.
I am using CubProg v 2.19, but I can't execute programming from stlink.
the logs are attached as a file.
Thank you
satoshi1
Satoshi1Author
Jun 5, 2025 12:37 AM UTC
Maryem
Jun 11, 2025 2:28 PM UTC
Hello @Satoshi1 ,
Thank you for your feedback, and apologies for the delayed response.
I couldn't reproduce the issue on my side. Could you please also share the flash size of your device and the Option Bytes configuration for further investigation?
Thank you,
Maryem.
