Andrew Neil
Mar 28, 2022 10:04 AM UTC
Typo in CubeProgrammer CLI help text
Clearly, the angle brackets for the 'port' option are mismatched.
It should say:
port=<PortName>
The error is repeated in UM2237 Rev 18 (the current version) - and note that the User Manual does not match the actual output:
Andrew Neil
Mar 28, 2022 10:50 AM UTC
Also, the documentation of 'noinit' is inconsistent with every other option taking a value:
0693W00000LvxsFQAR.pngTo be consisten, that should be:
[noinit=<noinit_bit>]: Set No Init bits, value in {0,1} ..., default 0
ie, angle-brackets around the value placeholder
