CHeck.1
STM32G431 connect over JTAG
I try to connect to a STM32G431 Device over JTAG. I got the following error. Has someone a solution for this error?
KnarfB
Did you upgrade to the latest tool version like STM32CuberProgrammer 2.6?
CHeck.1
CHeck.1Author
Yes I am using V2.6
KnarfB
Custom board? Nucleo32 works here as expected. What probe?
CHeck.1
CHeck.1Author
It is a self developed board. The JTAG connection works with an J-Link but not the ST-Link and STM32CubeProgrammer. Just a connection over SWD
KnarfB
Communication errors? You can lower the clock speed and re-check.
Uwe Bonnes
Chief
December 18, 2020
Firmware on the STLink recent? All STlink match JTAG ID against an internal list and reject parts they do not know(yet).
CHeck.1
CHeck.1Author
Firmware on ST Link is recent
Uwe Bonnes
Chief
December 18, 2020
Does connect under reset work?
CHeck.1
CHeck.1Author
No, it doesn't work
Uwe Bonnes
Chief
December 18, 2020
Double check your wiring, the problem is with 99.9% on your side. Get out the scope or LA and look at the signals.
