ADębs.1
Senior
Aug 24, 2021 6:12 AM UTC
STM32F7 Discovery, STM32CubeProgrammer
I cannot connect to program the STMF7 Discovery. In the attached file a message. What to do? regards
Andrzej
Aug 24, 2021 7:13 AM UTC
Based on your previous posts, I'm guessing you are erasing the flash in your program which can cause the debugger to disconnect during startup. Some solutions here:
https://community.st.com/s/question/0D50X0000B8jTfw/stlink-error-devtargetnothalted
You can always connect with STM32CubeProgrammer (under reset if necessary) and erase the flash to get back to a working state.
