STM32CubeProgrammer v2.24 released
We are pleased to announce that STM32CubeProgrammer 2.24 is available
What is new in 2.24:
- AI STM32CubeProgrammer Connector: MCP Server through STM32Cube for Agentic AI
- Binary file path list management: You can now remove an individual file from the list, open its location in your File Explorer, or clear the entire list.
- Enhanced Factory Reset display button: Find and use Factory Reset more easily to restore the default settings via a dedicated button in the Option Bytes panel.
- Less Intrusive Pop-ups & Better Logs for programming panels: Made the pop-ups less intrusive. Enhanced logs and reworked the GUI error messages to provide better user guidance.
- Save all memory: A new feature that saves the entire chip’s memory in one click, helping users save time and effort.
- Support SFI programming within the API
- Support of CM55 and CM85 in Fault Analyser.
- Enhanced cancel operation used in GUI
- Support of SFI with Key Wrapping (area W) for STM32U3 series and STM32V8.
- Support of Key Wrapping for STM32G55x/56x & STM32V8.
- STM32V8:
- Support cut2.2
- SFI via debug & UART interfaces
- Support of RDP Lock verification for ST32C5 series.
- Update of Key Wrapping architecture for STM32U3 series.
- STM32N6 cut 2.2: SSP & Debug Authentication
- STM32WL4: Programming when TZEN enabled and Boot on bootloader.
- FW encryption for G5, V8, H7P and WL4
- Serial Wire Viewer support for C5 series.
- Update SVD files to the latest versions
- STM32U396x/A6x:
- Internal memory programming through debug and bootloader interfaces
- Option bytes programming through debug and bootloader interfaces
- OTP programming through debug and bootloader interfaces
- Core register programming through debug interfaces
- Automatic mode
- Register viewer
- SWD Multidrop
- Incremental programming
- Firmware encryption/signing
- RDP regression with password
- Key Wrapping via debug interfaces
- SFI through debug interfaces
- STM32G55x/56x:
- Automatic mode
- Register viewer
- SWD Multidrop
- OBkey generation/provisioning
- Certificate generation
- Debug authentication
- STM32G534/544:
- Automatic mode
- Register viewer
- SWD Multidrop
- STM32H7P5/7P4:
- Automatic mode
- Register viewer
- SWD Multidrop
- External memory programming via debug interfaces
- STM32C5Q/5P:
- Automatic mode
- Register viewer
- SWD Multidrop
- STM32C5J/5K:
- Automatic mode
- Register viewer
- SWD Multidrop
How to get STM32CubeProgrammer 2.24:
- Under this link
- Or update your current installation of STM32CubeProgrammer using: Help > Software update
Main issues fixed in 2.24:
Refer to the online documentation here: Release details - STM32CubeProgrammer 2.24.0 documentation.
Known problems and limitations in 2.24:
Refer to the online documentation here: Release limitations - STM32CubeProgrammer 2.24.0 documentation.
