Mar 13, 2026 11:23 AM UTC
STM32CubeProgrammer installer stuck at Step 8 on Windows 11 Single Language
I tried to install STM32CubeProgrammer, but the installer always gets stuck at Step 8. I searched online and found that some people from my country solved the problem by changing the Windows region and language.
However, my Windows 11 license only supports a single language, so I cannot change it.
Is there any other solution for this issue?
Thanks in advance.
Kouthair
KouthairBest answer
Mar 24, 2026 9:25 AM UTC
Hello @goktug1,
Apologies for the delayed response.
It appears that this issue happens when installing on Windows 11 using certain languages other than english.
Fortunately, when you reach the step 8 all that is left is the shortcut creation and if you check the installation folder (which by default should be "C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer") everything should be there.
If you wish to create a shortcut of STM32CubeProgrammer, please head over to the \bin\ folder and send a shortcut of STM32CubeProgrammer.exe to your desired location.
Please let me know if you require more assistance on this matter.
Kouthair
KouthairBest answer
Hello @goktug1,
