BugMaker
May 9, 2022 2:37 AM UTC
STM32CubeProgrammer don't support CAN
In the introduce page of STM32CubeProgrammer, it descrips that this software support CAN bootloader interface, but I just find the ST-link Uart and USB. How can I configure it to CAN?0693W00000NpaF6QAJ.png0693W00000NpaEwQAJ.png
May 9, 2022 3:10 AM UTC
BugMaker
BugMakerAuthor
May 9, 2022 3:17 AM UTC
Many thank,In user manual, it shows the CAN shall be configured in ST-Link configuration pannel, But only JTAG and SWD selection in Port, it really confuse me~ As to you said, it required a adapater board & ST-Link could the trigger the CAN selection?
BugMaker
BugMakerAuthor
May 9, 2022 3:16 AM UTC
Javier1
Principal
May 9, 2022 7:32 AM UTC
Be aware that the STM32 builtin CANBUS bootloader can only be used if only 1 device (the one you want to flash) is connected to the bus.
https://community.st.com/s/question/0D53W00000apgoISAQ/is-the-stm-system-bootloader-trough-canbus-just-not-woking-when-more-than-one-device-shares-the-bus
hit me up in https://www.linkedin.com/in/javiermuñoz/
BugMaker
BugMakerAuthor
May 9, 2022 7:43 AM UTC
Thank to your reply, I find if I use the ST-LINK/V3SET & STM32CubeProgrammer, the adapter only provide tx/rx, it cann't be connected to the CAN bus directly. I give up using the STM32 bootloader and code a new one.
Javier1
Principal
May 9, 2022 7:57 AM UTC
There is plenty of cheap CANBUS transceiver boards.
Dont let that put you down.
Here is a hardware trick for your
