CWies.1
Sep 10, 2026 11:54 AM UTC
STM32CubeProgrammer Apple Silicon does not install TrustedPackageCreator_CLI in the correct folder
The oemirot provisioning tool expects the TrustedPackageCreator_CLI inside the same folder under mac osx silicone of the STM32CubeProgrammer. This yields an error for the provisioning.py script of these examples. So the python scripts won’t work anymore. I guess the development teams did not synchronise this fact.
Aziz BRIGUI
Sep 11, 2026 2:18 PM UTC
Hi ​@CWies.1,
On my side I can access both CLIs just fine from the base installation path. Could you please provide further details on the behavior you encountered? Also, I can’t find the provisioning.py file in CubeH5 FW pack (I just guessed that’s the device you’re using), could you please point it out?
Aziz
CWies.1
CWies.1Author
Sep 14, 2026 5:19 PM UTC
Please delete the complete folder from you macos silicon application and then try to install from scratch. You will see that the TrustedPackageCreator_CLI is installed in a separate folder and not like assumed from omirot in the same folder.
CWies.1
CWies.1Author
Oct 22, 2026 5:53 AM UTC
Any news regarding this?
