yurybotov
Dec 3, 2019 11:19 AM UTC
STM32CubeProgrammer 2.2.0 (Linux Mint) DFU mode - flash erase problems
Tested chips: stm32f405rgt6, stm32f411ceu6 (DFU bootloader - internal, libusb-1.0.0).
Then I try to erase one sector or range of sectors [X Y] - it is failed:
(I remove blank lines)
"./STM32_Programmer.sh -vb 2 -c port=USB1 -e 0
            STM32CubeProgrammer v2.2.0
USB speed  : Full Speed (12MBit/s)
Manuf. ID  : STMicroelectronics
Product ID : STM32 BOOTLOADER
SN     : 385C34733435
FW version : 0x011a
Device ID  : 0x0413
  AREA NAME     SECT.NBR    ADDRESS     SIZE     TYPE
  Internal Flash    0000     0x08000000   0016 KB   REW
            0001     0x08004000   0016 KB   REW
            0002     0x08008000   0016 KB   REW
            0003     0x0800c000   0016 KB   REW
            0004     0x08010000   0064 KB   REW
            0005     0x08020000   0128 KB   REW
            0006     0x08040000   0128 KB   REW
            0007     0x08060000   0128 KB   REW
            0008     0x08080000   0128 KB   REW
            0009     0x080a0000   0128 KB   REW
            0010     0x080c0000   0128 KB   REW
            0011     0x080e0000   0128 KB   REW
  Option Bytes     0000     0x1fffc000   0016 B    RW
  OTP Memory      0000     0x1fff7800   0512 B    RW
            0001     0x1fff7a00   0016 B    RW
  Device Feature    0000     0xffff0000   0004 B    RW
sending an abort request
setting the address pointer to address: 0x08000000
Device name : STM32F405xx/F407xx/F415xx/F417xx
Device type : MCU
Device CPU : Cortex-M4
Erase sector(s) ...
sending a clear status request
libusb control transfer error: -1
unable to switch the device to dfuIDLE/dfuDNLOAD_IDLE state
erasing sector 0000 @: 0x08000000 failed
Flash page/sector erase command correctly executed.
Note: if flash sector is protected, it will not be erased."
Then I erase all sectors - it is working good:
"./STM32_Programmer.sh -vb 2 -c port=USB1 -e all
SN     : 385C34733435
FW version : 0x011a
Device ID  : 0x0413
Device type : MCU
Mass erase ...
sending a full flash erase request
Mass erase command correctly executed.
Note: if there's any flash protection, it will not be erased."
dfu-util (v0.9) - working correctly.
