eGDY2CVw4jwV
Mar 9, 2020 10:08 AM UTC
STM32Cube Programmer CLI: What files are really needed?
I'd like to integrate the STM32CubeProgrammer CLI into my own windows tool.
Currently I'm investigating on the following questions:
  • What files from installation directory are necessary to use the CLI tool for UART DFU?
  • Can I safely remove some of the dlls, external flashloader files, GUI tools to reduce the size of the tool? (Almost 80 Mb!)
  • Will there be seperate releases of the CLI tool in the future , which do not contain all the GUI tools and libs, or at least a list of neccessary files, updated for each release?
Thank you and best regards!
Houda GHABRI
Mar 18, 2020 2:43 PM UTC
Hello @eGDY2CVw4jwV,
- For DFU usage only, you can remove the flash loader and external flashloader directories which are used only for JTAG connection
-You can also delete Cubeprogrammer_API.dll and STM32CubeProgrammer.exe which are used for GUI
-For the last point it is under study but I can’t confirm now if it will be done in short term.
Regards,
Houda
eGDY2CVw4jwV
Mar 18, 2020 2:49 PM UTC
Hi @Houda GHABRI​ ,
thank's for your answer!
 I'll evaluate your answer in the next days and see how far it's working!
Best regards
