SGasp.1
Oct 21, 2021 7:50 AM UTC
STM32Cube Programmer
Hi amazing forum..
I am wondering if there is a way to save as HEX file the memory read from the stm32 cube programmer..
I am asking this because I want to check that the bootloader that I am creating is exaclty writing what I expect ...
Thanks a lot guys
KnarfB
KnarfBBest answer
Oct 21, 2021 7:55 AM UTC
The blue Read button on the Device Memory tab has a dropdown triangle. Click it and select "Save as..." from the drop-down menu.
hth
KnarfB
KnarfB
KnarfBBest answer
hth
KnarfB
SGasp.1
SGasp.1Author
Oct 21, 2021 7:59 AM UTC
Hi KnarfB... I saw it ... it is saving as a bin file... I want to have a HEX file... it is easy for me to do the compariosn with hex values
Peter BENSCH
Oct 21, 2021 11:21 AM UTC
Just add the suffix .HEX to the filename.
/Peter
