Explorer
Jul 8, 2024 11:32 AM UTC
STM32 ST-Link Utility not working?
So i installed the st-link utility from my.st.com and did all the installation but when i run it, it tells me there are some .dll files missing. Specifically, these are the errors; 1st error; "The code execution cannot proceed because mfc140.dll was not found. Reinstalling the program may fix this problem" and the 2nd error is; "The code execution cannot proceed because MSVCP140.dll was not found. Reinstalling the program may fix this problem." . So i did exactly that, uninstalled the st-link utility and installed it again but still same problem. Does anyone have the same problem and how, if you fixed it, did you do it?
Peter BENSCH
Peter BENSCHBest answer
Jul 8, 2024 1:41 PM UTC
Welcome @null_byte, to the community!
the ST-LINK Utility is deprecated and already on NRND (Not Recommenden for New Design) anymore. Please use the STM32CubeProg instead.
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
