May 4, 2026 6:27 AM UTC
STM32 cube programmer HEX file loading
Hello Community,
I’m facing an issue while loading a firmware HEX file using STM32CubeProgrammer. The HEX file is not downloading successfully. Could you please suggest what might be wrong or provide guidance on how to resolve this?
isikli
May 4, 2026 7:05 AM UTC
This issue is usually not related to the HEX file itself but to configuration or connection problems. You may want to check points:
1) connection is ok ? make sure you selected the correct interface(st-link or uart or usb..)
2) mcu is powered ? if voltage is not detected, programming will fail.
3) if the mcu is protected RDP, can't programmed.
4) check your options bytes
Also please share the log output from the programmer.
Andrew Neil
May 11, 2026 1:44 PM UTC
Please give full details of what, exactly, you're using and how, exactly, it fails:
How to write your question to maximize your chances to find a solution
Can you download anything else to this target?
Can you download to any other target?
