Jul 17, 2023 7:05 AM UTC
STM32 Cube Programmer Hangs at step 8
While installing the program for my windows 10  it hangs at step 8 which is shortcuts set ups. So I have been reaserching the internet and forums for a while still didn't manage to find a solution
Yusuf
Jul 27, 2023 10:15 AM UTC
I have the same problem and still can't find a solution. I tried the setup in 4 computers and only one of them was successful and it was a coding pc which had many applications installed so maybe there is a software package that needs to be installed.
Sara BEN HADJ YAHYA
Jul 27, 2023 11:35 AM UTC
Hello @Gdovki , @Yusuf ,
Did you use Admin rights to install STM32CubeProgrammer?
Sara.
Yusuf
Jul 27, 2023 4:11 PM UTC
Yes, I tried using admin rights, different folder, 32-64 bit installers, installing java versions etc.
Best Regards.
May 15, 2024 10:00 AM UTC
We have the same problem. Tried on many computers. No luck. Anybody solved this problem on Windows 11?
Fatih_Yildirim
Jun 17, 2024 8:12 AM UTC
I believe this problem is related to your Windows Language. I had the similar issue in the past and changed my Windows language to English. Everything worked fine after that.
Dec 10, 2024 3:46 PM UTC
I was having this problem too. Your solution works. The language pack should be English for windows. Thanks.
Feb 13, 2026 7:08 PM UTC
Even though I've set my computer's language to English, I can't install it. Also, there doesn't seem to be anything unusual in the installation directory.
