ÖÇoba.1
Nov 11, 2020 2:40 PM UTC
Stm32 code reading
I have a Stm32 which was coded by my friend. I want to reach this code and I want to change some thing. How can I do it.(note: code doesnt have reading protection)
Peter BENSCH
Nov 11, 2020 4:32 PM UTC
This will depend on your time you want to spent and other resources, as changing a binary or even decompiling a binary file into a readable form is an extremely demanding task.
Good luck!
/Peter
ÖÇoba.1
ÖÇoba.1Author
Nov 11, 2020 8:31 PM UTC
İt is easy for pic programing or others . Are you pozitive that there is not any way to read stm code .
Nov 11, 2020 8:54 PM UTC
Read it how?
The STM32 Cube Programmer can easily dump the code to a .BIN or .HEX
What you do after that is up to you.
You can disassemble and patch it as you would most any other MCU code.
ÖÇoba.1
ÖÇoba.1Author
Nov 11, 2020 10:29 PM UTC
Thank you for helping. By the way is there any example or source to take the Hex code with Cube programmer ?
Nov 11, 2020 10:37 PM UTC
The simplest solution is to ask your friend for the source code and change it there.
