Dec 12, 2023 8:37 AM UTC
STLink V2 Not recognizing STM32CubeProgrammer?
ST Link not recognizing STM Cube Programmer? - From screenshot you can see NO ST Link detected in serial number drop down and has no target information. I can (and did) upgrade firmware, On doing so, it's throwing following error( ST-Link device lost when exiting upgrade mode). Still won't connect. Keep getting "UR connection mode is defined with the HWrst reset mode" log entry.
AScha.3
AScha.3Best answer
Dec 12, 2023 11:13 AM UTC
so: same stlink working before ? and no update made ?
because this is exactly , what newer stm program doing, when detecting a clone. (or non stm cpu)
otherwise...try new USB cable and /or other port on PC.
AScha.3
Dec 12, 2023 9:12 AM UTC
read:
https://community.st.com/t5/stm32-mcus-boards-and-hardware/blue-pill-driving-me-crazy/m-p/618004#M16204
>> I suspect there's something in the latest (last year or so) versions of STM32CubeIDE that causes fake programmers to fail. You could also use a version from before that, will probably work.
Dec 12, 2023 11:04 AM UTC
Hi AScha.3,
I'm using wio E5 Development board from seeed(https://wiki.seeedstudio.com/LoRa_E5_Dev_Board/#lorawan-end-node). Also, the ST-Link device is not clone. It was working fine earlier, all of sudden it's throwing error.
AScha.3
AScha.3Best answer
