Nov 7, 2024 6:17 AM UTC
st link v2 red led is on
Hello
The LED on the top link is red. Is it a problem with the connection or the driver? I can't figure it out. Can you help me?
Andrew Neil
Nov 7, 2024 10:04 AM UTC
Please see this for how to capture a screenshot - far better than photographing the screen!
https://www.techrepublic.com/article/how-to-take-screenshots-in-windows-10/
The pop-up message is telling you that it can't detect any connected STM32 target device:
The log shows you that the target supply voltage is only 0.46V
Your Target can't be running with less than half a volt supply!
You need to fix the power supply on the target.
Note that the ST-Link/V2 does not supply power to the target.
osman2Author
Nov 7, 2024 10:55 AM UTC
I know how to take a screenshot but the computer I took it on didn't have internet so I took it with my phone
Should I connect another device to the st-link instead of the computer's usb port?
Thank you for your interest
Andrew Neil
Nov 7, 2024 10:11 AM UTC
The meaning of the LED is described in the User Manual:
https://www.st.com/resource/en/user_manual/um1075-stlinkv2-incircuit-debuggerprogrammer-for-stm8-and-stm32-stmicroelectronics.pdf#page=15
So the PC is communicating with the ST-Link, but the ST-Link has not yet had any communication - successful or otherwise - with the Target.
As described in my previous post, your ST-Link can't communicate with your Target because the Target has no power.
The ST-Link can't distinguish this condition from simply having no target connected at all.
osman2Author
Nov 7, 2024 11:08 AM UTC
I apologize, but I plugged it into other ports, but for some reason the voltage does not increase and stays at 0.46
Andrew Neil
Nov 7, 2024 11:15 AM UTC
Again, the ST-Link does not supply power to the Target.
Your screenshot shows that the PC is communicating fine with the ST-Link;  there is no problem there - no need to try different USB ports.
The problem is that your Target is not powered.
How are you trying to power the Target?
What Target is it?
Nov 7, 2024 11:28 AM UTC
You don't have anything connecting to Pin 1 which should be the VTarget voltage to power the interface buffers on the ST-LINK side
osman2Author
Nov 7, 2024 11:36 AM UTC
Do I need to give 3.3v from pin1 of the cn3 socket?
Andrew Neil
Nov 7, 2024 11:51 AM UTC
Again, see the User Manual - it tells you what connections you need to make between the ST-Link and your Target:
CN3 pin 1 (and pin 2) connects to the power supply (VCC) in the Target - it is an input to the ST-Link.
The voltage reported in the Log is what the ST-Link measures at this input.
osman2Author
Nov 7, 2024 11:54 AM UTC
Dear Andrew
Thank you in advance for your answer.
I have an electronic board I have an electronic board I have a cpu using stm32f103
according to the connection in the socket in the following picture I am connecting to the cn3 socket according to the photo I am connecting 1=1--2=3---3=9---4=7--- 5=20
I can't find where I went wrong.
Andrew Neil
Nov 7, 2024 12:03 PM UTC
Again, look at the User  Manual:
Plus you need a GND connection - any one will do.
Since you are only using 2 pins for debug (plus NRST), you must be using SWD.
It would be more helpful to label your schematic with the SWD names (rather than JTAG names):
  • JTCK = SWCLK
  • JTMS = SWDIO
Andrew Neil
Nov 7, 2024 12:06 PM UTC
