T B
Mar 3, 2021 9:15 AM UTC
Save/load STM32CubeProgrammer GUI settings
Is it possible to save the current GUI setting settings (e.g. file names and path, start address, erase option, ST-Link config)?
Houda GHABRI
Houda GHABRIBest answer
Mar 8, 2021 11:38 AM UTC
Hi @Bacteriuslocher​ ,
The currents GUI settings are saved in C:\Users\userName\STMicroelectronics\STM32CubeProgrammer\config.properties .
Several parameters already exists but if you need some extras parameters to be saved we can add them.
If your question is answered, please close this topic by choosing Select as Best. This will help other users find that answer faster.
Houda
Houda GHABRI
Mar 5, 2021 10:42 AM UTC
Thanks for your feedback.
The saving of the current settings (path ,file name, start address and ST-link config) is already done in the current version of STM32CubeProgrammer .
If not for you, can you please give me the STM32Cuberogrammer version to check?
Houda
T B
T BAuthor
Mar 5, 2021 3:09 PM UTC
Hi Houda,
thanks for your answer.
I am on version 2.6.0. I assume this is the latest version.
Maybe I am just bind and cannot find it. Can you give a hint where I can find it?
Thomas
Houda GHABRI
Houda
Explorer
Jan 15, 2025 3:58 PM UTC
Is it possible to leave the default configuration every time you start the STMcube programmer?
Is the Shared option set to Enabled?
In the file:  \STMicroelectronics\STM32CubeProgrammer\config.properties
I can't find any "Shared" variable.
The version of STMcube programmer is 2.18.0
