RSoen.1
Feb 24, 2021 10:40 PM UTC
Reset when try to connect to Bootloader (USB)
STM32L073RZ
We are entering the BL via boot0. The STM32Cube Programmer software sees the USB port but when I try to connect, the part resets out of the bootloader.
Appreciate any ideas.
Rich
Houda GHABRI
Houda GHABRIBest answer
Feb 26, 2021 1:21 PM UTC
Hi @RSoen.1​ ,
Thanks for your feedback.
Indeed, this problem is already raised and will be corrected in the next STM32CubeProgrammer release available very soon.
Hope this helps you, when your question is answered please close this topic by choosing Select as Best this will help other users find that answer faster.
Houda
Houda GHABRI
Hi @RSoen.1​ ,
Houda
RSoen.1
RSoen.1Author
Feb 28, 2021 5:54 PM UTC
Well I am glad it is not a bug in my code or worse yet the bootloader.
When will the next rev be released?
Are there other software tools that support the USB bootloader?
Rich
Houda GHABRI
Feb 28, 2021 9:37 PM UTC
Hi @RSoen.1​
You can use the Dfuse tool available on st.com.
Please pay attention that drivers for STM32CubeProgrammer and Dfuse are not compatibles , You need to remove manually the CubeProgrammer driver before using Dfuse.
Houda
RSoen.1
RSoen.1Author
Apr 20, 2021 2:52 PM UTC
Hello ST ......
