Sep 12, 2025 10:34 AM UTC
Optimize stm32cubeprogrammer folder size to use STM32_Programmer_CLI.exe line command only
Hello
I am in the industrialization phase of a product based on STM32G0B0RE.
In order to optimize the flashing process for my manufacturer I made a .bat file programming the product the MCU using the STM32_Programmer_CLI.exe commmand from STM32CubeProgrammer.
Since I am not using the GUI of STM32CubeProgrammer is there any folder I can delete in the root to optimize the size of the package I'll provide. The STM32CubeProgrammer size is 1,36 Go if I can reduce it to 500 or 600 mO it could be very usefull.
Best Regards
Thibaud
Aziz BRIGUI
Aziz BRIGUIBest answer
Sep 16, 2025 1:58 PM UTC
Hello @Tiboww,
You can use the STM32CubeProgrammer package bundled in STM32CubeCLT in STM32CubeCLT | Software - STMicroelectronics, after installing, you can find the package in this directory:
C:\ST\STM32CubeCLT\STM32CubeProgrammer
The package is around 130 MBytes and is CLI only.
Hope this helps,
Aziz
Aziz BRIGUI
Hello @Tiboww,
Hope this helps,
Aziz
TibowwAuthor
Sep 29, 2025 10:18 AM UTC
Hello
It is perfect thank you.
Thibaud
