TMich.1
Feb 15, 2023 9:52 AM UTC
locked out of my stm32g431.
made my own board with stm32g431kb and accidentally disabled swd. I can't acces my board anymore and pulling up boot0 doesn't help.
Javier1
Principal
Feb 15, 2023 10:00 AM UTC
Youre not locked out , try this:
  • CubeMx CubeProgrammer with Power down or under reset mode0693W00000YAmQYQA1.png
  • If that doesnt work you need to do the reset SW raindance.
  1. Hold the board in reset
  2. Release the reset and inmediately press Connect in cubeProgrammer
hit me up in https://www.linkedin.com/in/javiermuñoz/
TMich.1
TMich.1Author
Feb 15, 2023 10:26 AM UTC
is this cubemx or cubeide? in dube ide and cubemx I don't see the tab from your picture. and also do this with or without boot pulled up?
KnarfB
Feb 15, 2023 10:30 AM UTC
CubeProgrammer
Piranha
Principal III
Feb 19, 2023 8:41 PM UTC
Connect the NRST pin to debugger and set those in CubeProgrammer:
Connect mode: Under Reset
Reset mode : Hardware reset
TMich.1
TMich.1Author
Feb 19, 2023 9:57 PM UTC
I tried this with no succes
