ATSEM.1
May 22, 2023 3:14 PM UTC
issues in running stm32u5_tool.sh file from X-Cube AWS package because of stm32Programmer
These are the 1st lines of stm32u5_tool.sh file from X-Cube AWS package.
#!/bin/bash
# Find STM32_Programmer_CLI
# shellcheck disable=SC2154
if [ -n "${cubeide_cubeprogrammer_path}" ]; then
    PROG_BIN_DIR="${cubeide_cubeprogrammer_path}"
    PROG_BIN_PATH=$(find "${cubeide_cubeprogrammer_path}" -name 'STM32_Programmer_CLI*' -type f)
    PROG_BIN=$(basename "${PROG_BIN_PATH}")
    export PATH="${PROG_BIN_DIR}:${PATH}"
elif command -v STM32_Programmer_CLI; then
    PROG_BIN="STM32_Programmer_CLI"
else
    echo "Error: STM32_Programmer_CLI could not be found."
    echo "STM32_Programmer_CLI in not in your path and the cubeide_cubeprogrammer_path environment variable was not defined."
    exit 1
fi
When I run this file in the cmd , I get this error: " Error: STM32_Programmer_CLI could not be found. STM32_Programmer_CLI in not in your path and the cubeide_cubeprogrammer_path environment variable was not defined. "
I installed smt32Programmer in the same path as my stm32u5_tool.sh and nothing changed.
