Issue with STLink-server
- 4 replies
- 588 views
Dear community supporters,
I would like to add ability to share STM32 projects platforms to my team. I have setup a server on Debian 13 and setup the STLink server tool, and using a SSH tunnel to do port forwarding from the attached STLink port on the linux server (localhost:7184) to a Windows client machine where I plan to use the STM32 Cube IDE, STM32 Cube Programmer.
The tunnel is operational, and I have added a wireshark capture showing discussion from my Windows client when using the STM32 Cube Programmer, and a log from a STM32 Cube IDE debug configuration. For both, the Shared STLink is ticked, and in STM32 Cube IDE, I am able to see (the snapshot STM32 Cube IDE Debug Configuration.png shows it) the STLink SN from my remote STM32 Nucleo board attached to my linux server. Though, the STM32 Cube Programmer is unable to show the SN, seems it is unable to detect the probe devices, as shown in the st-link_gdbserver_log when starting the debug session.
It seems the STM32Cube Programmer is causing the issue when the stlink_server remote port forwarding is active, and gives the error 'Error: No debug probe detected.'. It seems the GDB session does take in consideration the STLink server, but the STM32Cube Programmer error indicates where it stops.
Is someone from ST could shed some light on this issue and comment on my notes, thanking them by advance
Best regards,
Emmanuel POITIER
