MSSloan1962
Oct 5, 2022 8:19 AM UTC
Is it possible to change location of Data_Base directory?
I'm writing a C# version of the USB_Example program. You can set the loader path using the setLoadersPath call, but the path of the Data_Base directory seems to be fixed to "/../Data_Base/<whatever you are trying to connect to>.html. Is there any way of changing this path too? I'm using the latest 2.11 API
Aziz BRIGUI
Aziz BRIGUIBest answer
Oct 6, 2022 3:52 PM UTC
Hello @MSSloan1962​,
Thank you for posting,
Unfortunately for now, there's no way to modify the Data_Base path. However, the feature is now requested from STM32CubeProgrammer development team.
Internal ticket number:  98648 (This is an internal tracking number and is not accessible or usable by customers)
I will keep you posted with updates.
Aziz
Aziz BRIGUI
Aziz
Pavel A.
Oct 7, 2022 6:02 PM UTC
Until this improvement is done, you can create a directory symlink in your app dir.
