Oct 2, 2024 8:45 AM UTC
Installing SFI remotely on NUCLEO-U575ZI-Q
I have generated a SFI file and managed to install it on my NUCLEO-U575ZI-Q using STM32CubeProgrammer. Now, as a next step, I want to install this SFI file remotely (e.g. on another PC or similar), is there any way to do this installation, or does it have to be connected to a PC that has STM32CubeProgrammer? Either via SSH or something similar.
Best regards and thanks in advance.
Oct 5, 2024 7:26 AM UTC
To install the SFI file remotely on your NUCLEO-U575ZI-Q, you typically need a method to flash the firmware without being directly connected to a PC running STM32CubeProgrammer. While STM32CubeProgrammer is primarily designed for local installations. Hope! it would be helpful.
