Nov 1, 2024 8:58 AM UTC
inconsistent designation of registers
In the CubeProg, (for instance) the RCC_D1CCIPR value names (*SRC) are different than in the RM 0433 (*SEL). Such things are a bit annoying, if one tries to find things by a keyword search, of if unsure about "is it really the same entity"? Can someone here pass this to the authors for fixing? Thank You!
pkoevesdi_0-1730451210735.png - CubeProgrammer v2.17.0
pkoevesdi_1-1730451330120.png- RM0433 Rev. 8, p. 496
STTwo-32
STTwo-32Best answer
Nov 1, 2024 9:14 AM UTC
Hello @pkoevesdi
Thank you for feedback that has been escalated for correction on one of the future releases of the STM32CubeProgrammer (under internal ticket number 195558 ).
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @pkoevesdi
Best Regards.
STTwo-32
Andrew Neil
Nov 1, 2024 9:22 AM UTC
Does this also apply to the names used in the generated source code?
pkoevesdiAuthor
Nov 2, 2024 6:33 AM UTC
You mean in CubeMX? Didn't try that, because I don't develop in C. I only use CubeProg for reading and saving registers.
Andrew Neil
Nov 2, 2024 9:31 AM UTC
@pkoevesdi wrote:
You mean in CubeMX?
Yes - the code generated by CubeMX.
