Ebun.1
Senior
Jan 18, 2021 5:53 AM UTC
I want to write a TouchGFX hex file using STM32CubeProgrammer
Thank you for helping.
environment:
STM32CubeProgrammer Ver2.6.0
TouchGFX Ver4.15.0
Board: STM32F769I-DISCO etc.
Is it possible to write a hex file created by TouchGFX using STM32CubeProgrammer?
I want to write a program to internal and external flash via UART without using SWD.
Thank you.
Houda GHABRI
Houda GHABRIBest answer
Jan 21, 2021 7:01 PM UTC
Hi @Ebun.1​ ,
Flashing external memory is possible only using SWD.
If you want to use SWD you can use this command:
STM32_Programmer_CLI.exe -c port=swd mode=UR -el ExternalLoader\MX25L512G_STM32F769I-DISCO.stldr  firmware.hex
Houda
Houda GHABRI
Hi @Ebun.1​ ,
Houda
Ebun.1
Ebun.1Author
Senior
Jan 22, 2021 4:21 AM UTC
Hi Houda
Thank you for your answer.
