DBenn.1311
Nov 17, 2019 2:29 AM UTC
I installed STM32CubeProgramme twice but both times it shows the splash screen then exits. Anyone having a similar experience or know how to fix the problem? Thanks ya'lll.
DBenn.1311
DBenn.1311Best answer
Nov 18, 2019 11:56 PM UTC
Hi Oliver,
I found another question similar to mine with a lead to the solution. The solution was to uninstall all of my JDKk and Java 8 update 231, then install the cube programmer, then reinstall the Java update. Since then all is well.
Thanks for your response.
Dan
Olivier GALLIEN
Nov 18, 2019 1:24 PM UTC
On which OS are you installing CubePro ?
Did you refer to UM2237 for installation ?
Olivier
DBenn.1311
DBenn.1311AuthorBest answer
Hi Oliver,
Dan
