Apr 11, 2024 3:23 AM UTC
I can't connect to STM32F103C8T6 using STM32CubeProgrammer
I tried to connect but it's always: "No STM32 target found! If your product embeds Debug Authentication, please perform a discovery using Debug Authentication"
I also try "Under reset" mode but still not working.
Can someone help me
mƎALLEm
mƎALLEmBest answer
Apr 11, 2024 7:32 AM UTC
Sorry this is neither ST’s board (blue pill most probably with a contrefit chip) nor an ST’s ST-link (copied ST-Link), I cannot help you.
mƎALLEm
Apr 11, 2024 3:55 AM UTC
Are using a USB data cable or charging cable?
chin-suAuthor
Apr 11, 2024 4:00 AM UTC
I used USB data cable
mƎALLEm
Apr 11, 2024 4:04 AM UTC
What is the board are you using? ST board? Custom board?
Check the power supply of the MCU.
ST-Link firmware updated?
Show a schematic
Error suggests chipsnis not powered or connected correctly.
Make sure the ST-LINK gets the VTarget power from the board.
chin-suAuthor
Apr 11, 2024 4:03 AM UTC
I think i connected correct
