burak.colak
May 7, 2021 1:45 PM UTC
I am unable to establish a cubeprogrammer.
0693W00000ANgdkQAD.jpg0693W00000ANgdaQAD.jpgWhen the installation comes to the 7th step, it does not do anything, it wants me to exit the installation. When I looked at the directory where the program should be installed, there is no exe file.
TDKBest answer
May 7, 2021 6:30 PM UTC
EXEs are in the bin directory.
TDKBest answer
May 7, 2021 7:26 PM UTC
Perhaps there is an issue with administrative rights?
Have your IT staff install the application, or use "Run As Administrator" when installing.
Works here so assume something specific to your machine/configuration, which you'll need to get deeper into if you expect to find a solution, or report an issue.
burak.colak
May 10, 2021 5:34 AM UTC
thanks problem solved. Exe file is in the bin folder that I noticed. It worked when I turned it on.
