Jan 12, 2026 11:11 AM UTC
HSM reader detection
Hi, using STM32 Cube Programmer and STM32 Trusted Package Creator W2.21, I was unable to detect the HSM card, getting error 0x88000002. I had to downgrade to V2.14, as mentionned in several posts to get it detected successfully.
I use HID Omnikey 3121 reader.
Any solution to be able to use last version 2.21 and HSM card ?
Aziz BRIGUI
Aziz BRIGUIBest answer
Jan 12, 2026 4:15 PM UTC
Hi @PLencou,
I can't reproduce the behavior you're seeing, but I don't have the exact reader you're using on hand. According to the last comment on this thread, installing STM32CubeProgrammer to a different path resolved the issue for v2.16. Could you try that and get back to me? Also, can you detect the HSM in STM32CubeProgrammer here ?
Aziz
Aziz BRIGUI
Hi @PLencou,
Aziz
PLencouAuthor
Jan 14, 2026 8:18 AM UTC
I confirm it works after I did the installation of the latest version V2.21 on a different folder. Note: I haven't uninstalled the previous version 2.14. Then both version could detect the HSM card and I could program the HSM card successfully.
Thank you for your valuable support.
