MKemp.1
Apr 1, 2020 3:33 PM UTC
How to use STM32CubeProgrammer over CAN Bus?
Hi, are there any information's or app-notes available how to use this programmer over CAN bus. I cant find any information which hardware is supported or how make the can hardware on my laptop visible to the programmer.
Thanks for your support!
Tesla DeLoreanBest answer
Apr 1, 2020 3:51 PM UTC
To the best on my knowledge the CAN support in STM32CubeProgrammer is via the STLINK/V3SET boards. The API also has examples.
For the CAN protocol implementation use the following app note, and code a solution for your PC side CAN implementation/drivers
https://www.st.com/resource/en/application_note/cd00264321-can-protocol-used-in-the-stm32-bootloader-stmicroelectronics.pdf
The support costs for third-party CAN implementations is likely too high, and if you have specific hardware/software you're familiar with, implementing the protocol should be straight-forward enough.
MKemp.1
MKemp.1Author
Apr 2, 2020 7:55 AM UTC
Thanks, I ordered a STLINK/V3SET .
Maybe I'll write my own Software as well. Thanks !
Oct 19, 2023 4:44 PM UTC
Hello
If you are developing custom bootloader and planning to use STLINK-V3SET., please email me as I have developed custom Bootloader and not able to connect with STLINK-V3SET. Kindly email me if you are available.
sivakumar.mariappan@electro-flight.com.
Siva
