Feb 23, 2024 6:23 PM UTC
How to uninstall CubeProgrammer on macos?
Is it enough to drag-drop the app from Application folder to thrash bin or is there anything else I should do?
Feb 24, 2024 10:24 PM UTC
Hello @ubaldot
Can you try the steps in the following forum post : Solved: Can't uninstall STM32Cube Programmer V2.5.0 from W... - STMicroelectronics Community
Otherwise, there is an unistaller .bat script in your installation directory
C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\Uninstaller
Tell me if ti answer your question, otherwise I will share with dev team !!
Best Regards,
Younes
ubaldotAuthor
Feb 25, 2024 5:45 AM UTC
Thanks for your reply.
However the suggested method won’t apply to my case because I am running on macos, as stated in the title. If you could share my issue with the dev team I would be grateful.
