This happened to me just now when I loaded a pin configuration meant for a STM32F411VET6 to a STM32F411CEU6.
As rubenayl said, connect while holding reset. In my case I had to keep doing this every time I wanted to connect to the chip. What worked for me was doing a "Full chip Erase" using the STM32CubeProgrammer.
ofer-bahar
Hello AVall
the problem is this BOOT0 in a wrong state probably due to earlier programming, take a look on this paragraph from the user manual
So... in the H747-DISCO board you have to
1. unplug the USB ST-LINK
2. unmount the LCD,
3. short R192 - keep it short circuit
4. plug the USB ST LINK
5. now it boots with BOOT0 = '1'
now you can program,
after program you can put the LCD back
Ofer
