Sep 10, 2025 3:18 AM UTC
How to delete file path history in STM32CubeProgrammer
Hi
There is a file path window on the Erasing&Programming page.
I would like to reset the history because the path history increases every time I change the file I write.
Is there a way to reset the history?
 STM32CubeProgrammer Version:v2.16.0
OS:Windows11
Regard
Peter BENSCH
Peter BENSCHBest answer
Sep 12, 2025 3:06 PM UTC
Although there is currently no built-in option to delete the file path list within the STM32CubeProgrammer, it is possible to edit it manually in the file config.properties. There you will find a line beginning with downloadFileList= which lists the complete paths of the last files separated by commas. In Windows, this file is typically located in the directory
%USERPROFILE%\STMicroelectronics\STM32CubeProgrammer
%USERPROFILE% refers to your own user directory, where settings for various programmes are typically stored. Simply paste this path into the address bar of Explorer and press Enter.
WARNING: You are fully responsible when accessing this directory, so please be very careful not to destroy your settings or those of the respective user.
Hope that helps?
/Peter
MGogr.1
Senior
Sep 10, 2025 4:18 AM UTC
Currently there seems to be no option of deleting the path history.
ToshikiAuthor
Sep 10, 2025 4:24 AM UTC
Hi
Thank you for your reply.
I realized there were no options.
Regard
Peter BENSCH
Hope that helps?
/Peter
