KDJEM.1
KDJEM.1Best answer
Oct 9, 2025 2:13 PM UTC
Hello @willisk;
As mentioned in RM0486 the boot mode is determined by BOOT0 and BOOT1 pins, and one OTP word. You can boot source from flash when BOOT0=0 and BOOT1=0.
BOOT0 is a dedicated pin latched upon reset release.
The BOOT1 is a non dedicated boot pin. The BOOT1 value comes from BOOT1 pin (default
pin), or any other pin defined by BSEC BOOTROM_CONFIG10 - OTP_WORD19[28:21] =
dev_boot_port + dev_boot_pins.
I hope this help you.
Thank you.
Kaouthar
KDJEM.1
KDJEM.1Best answer
Hello @willisk;
Thank you.
Kaouthar
