Nov 27, 2023 10:57 AM UTC
FDCAN Bootloader in STM32G474RCT6
I am using STM32G474RCT6 microcontroller, I want perform firmware upgrade through CAN communication. But my controller doesn't provide the feature of Firmware upgrade through CAN communication.
is there any possibility to use CAN communication for firmware upgradation in my controller.
    FBLBest answer
    Nov 28, 2023 11:23 AM UTC
    Hello @Sri_Nishanth,
    According to AN2606, FDCAN bootloader is not supported on G4 series. An internal ticket is submitted to update the AN5405
    FBLBest answer
    Oct 8, 2025 12:59 PM UTC
    It seems the documentation has never been updated, do you still plan to fix this?
    Nov 28, 2023 12:51 PM UTC
    Hello @FBL
    There is a requirement to update firmware using CAN only.
    What other options are available to use this apart from designing a custom bootloader ?
    Nov 28, 2023 5:27 PM UTC
    Hello again, @Sri_Nishanth
    Check the following example using OpenBootloader
    STM32Cube\Repository\STM32Cube_FW_G4_V1.5.1\Projects\STM32G474E-EVAL\Applications\OpenBootloader
