Mar 31, 2025 3:59 PM UTC
Error trying to install 32cubeprg 2.19.0 Linux
On Kubuntu 24.04 when double clicking on
SetupSTM32CubeProgrammer-2.19.0.linux
an empty window appears and then closes again.
If I run
via the terminal (as admin or as user), I get this error:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
 at sun.awt.X11FontManager.getFileNameFromPlatformName(X11FontManager.java:174)
 at sun.font.SunFontManager.initCompositeFonts(SunFontManager.java:3506)
 at sun.font.SunFontManager.access$800(SunFontManager.java:65)
 at sun.font.SunFontManager$2.run(SunFontManager.java:555)
 at java.security.AccessController.doPrivileged(Native Method)
 at sun.font.SunFontManager.<init>(SunFontManager.java:386)
 at sun.awt.FcFontManager.<init>(FcFontManager.java:35)
 at sun.awt.X11FontManager.<init>(X11FontManager.java:57)
 at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
 at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
 at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
 at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
 at java.lang.Class.newInstance(Class.java:442)
 at sun.font.FontManagerFactory$1.run(FontManagerFactory.java:83)
 at sun.font.FontManagerFactory.getInstance(FontManagerFactory.java:74)
 at sun.font.SunFontManager.getInstance(SunFontManager.java:250)
 at sun.font.FontDesignMetrics.getMetrics(FontDesignMetrics.java:264)
 at sun.swing.SwingUtilities2.getFontMetrics(SwingUtilities2.java:1125)
 at javax.swing.JComponent.getFontMetrics(JComponent.java:1626)
 at sun.swing.SwingUtilities2.getFontMetrics(SwingUtilities2.java:372)
 at sun.swing.SwingUtilities2.getFontMetrics(SwingUtilities2.java:345)
 at javax.swing.plaf.basic.BasicLabelUI.paint(BasicLabelUI.java:182)
 at javax.swing.plaf.ComponentUI.update(ComponentUI.java:161)
 at javax.swing.JComponent.paintComponent(JComponent.java:780)
 at javax.swing.JComponent.paint(JComponent.java:1056)
 at javax.swing.JComponent.paintChildren(JComponent.java:889)
 at javax.swing.JComponent.paint(JComponent.java:1065)
 at javax.swing.JLayeredPane.paint(JLayeredPane.java:586)
 at javax.swing.JComponent.paintToOffscreen(JComponent.java:5217)
 at javax.swing.BufferStrategyPaintManager.paint(BufferStrategyPaintManager.java:290)
 at javax.swing.RepaintManager.paint(RepaintManager.java:1272)
 at javax.swing.JComponent.paint(JComponent.java:1042)
 at java.awt.GraphicsCallback$PaintCallback.run(GraphicsCallback.java:39)
 at sun.awt.SunGraphicsCallback.runOneComponent(SunGraphicsCallback.java:79)
 at sun.awt.SunGraphicsCallback.runComponents(SunGraphicsCallback.java:116)
 at java.awt.Container.paint(Container.java:1978)
 at java.awt.Window.paint(Window.java:3906)
 at javax.swing.RepaintManager$4.run(RepaintManager.java:842)
 at javax.swing.RepaintManager$4.run(RepaintManager.java:814)
 at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
 at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:814)
 at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:789)
 at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:738)
 at javax.swing.RepaintManager.access$1200(RepaintManager.java:64)
 at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1732)
 at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
 at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
 at java.awt.EventQueue.access$500(EventQueue.java:97)
 at java.awt.EventQueue$3.run(EventQueue.java:709)
 at java.awt.EventQueue$3.run(EventQueue.java:703)
 at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
 at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
 at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
 at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
 at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
 at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
 at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
SEVERE: The language pack couldn't be initialized.
Action invocation failed
SEVERE: com.izforge.izpack.api.exception.IzPackException: java.lang.NullPointerException
Aziz BRIGUI
Aziz BRIGUIBest answer
Apr 18, 2025 4:15 PM UTC
Hello @AndriiGalinovskyi
Please check this thread: Solved: Re: After upgrade to CubeProgrammer 2.18.0 cannot ... - STMicroelectronics Community
Hope it helps !
Aziz
Aziz BRIGUI
Hope it helps !
Aziz
mx_chAuthor
Oct 27, 2025 10:23 AM UTC
OK, so the answer is: STM Cube Programmer does not run on KDE and KDE users should just install a different Linux distro to be able to run STM Cube Programmer.
mx_chAuthor
Oct 28, 2025 9:01 AM UTC
Or to be more specific: Maybe CubeProgrammer would run on KDE, but we can't know, because the package ST is using in their installer for uncompressing the binary for installation is failing under KDE. If someone sends me an unpacked binary, I could try if it runs. Honestly, ST should just modernize their app so it comes in a flatpack/snap/Appimage, or go the different route and provide the binary.
mx_chAuthor
May 2, 2026 1:33 AM UTC
For anyone having the same issue:
THE SOLUTION IS TO RUN THE INSTALLER WITHOUT A GUI.
./SetupSTM32CubeProgrammer-2.22.0.linux -console
