jju.1
May 11, 2023 12:07 AM UTC
Error: Problem occured while trying to connect
l want to connect pcb board through stm32cubeprogrammer.
But it posts pop-up like that.
The error massage is "Error: Problem occured while trying to connect".
And sometimes it connects well, so i can't find the reason.
Could you give me some adivce to this problem?
AScha.3
AScha.3Best answer
May 15, 2023 6:14 AM UTC
again...
  1. Update the ST-LINK firmware.
  2. set to swd , not jtag
_legacyfs_online_stmicro_images_0693W00000bk3geQAA.pngyou have old firmware, V29 ; now is V40 ...about.
Piranha
Principal III
May 13, 2023 11:01 AM UTC
  2. Do you actually have a JTAG connection, not SWD?
  3. If low-power modes are used, it is recommended to use "Connect mode: Under Reset" and "Reset mode: Hardware reset".
jju.1
jju.1Author
May 15, 2023 5:52 AM UTC
Hello.
I've already downloaded the latest version from this site, and I've checked the jtag connection. And sometimes they connect well. If i try 100 times, it will be connected about 1 time, and in that state, the connection will be good until the computer is turned off.
AScha.3
AScha.3Best answer
again...
jju.1
jju.1Author
May 15, 2023 6:56 AM UTC
oh it connects well. I really appreciate your hep. Thanks a lot!!
