Error 'Invalid Delay value' when connect using UART protocol
STM32CubeProgrammer v2.21.0
PhumphathaiBest answer
Hello
I update to this version 2 day ago. Now I uninstall and reinstall with v2.19.0
I haven't found any new updates.
Maybe I update to Test on Production Version.
Thank you.
KDJEM.1
Hello @Phumphathai and welcome to the community;
Could you please give more detail about the issue, which STM32 are you using? Are you using STM32 board?
Could you please check the STM32CubeProgrammer version? The latest STM32CubeProgrammer version is 2.19.0.
Could you please try to update your toolchain and to use STM32CubeProgrammer 2.19.0 version
Please let me know if the issue is solved or not?
Thank you.
Kaouthar
Hello
I use STM32L476VG with custom board. But without any board connect to USB to UART this still happen.
I use STM32CubeProgrammer v2.21.0 I think this is latest version
As @Pavel A. show. Delay Pulse text box is read only and cannot fill any value
Thank you
Andrew Neil
So, presumably, this must be coming from some configuration that you should supply?
And that value is missing or invalid.
The first message just tells you that it's using a default instead.
The rest of the video shows that there is no response from your target.
Of course it would - with no board connected, there will certainly be no reply!
So please give details - schematic?
Are you using the System Bootloader, or a custom bootloader?
How to write your question to maximize your chances to find a solution.
Andrew Neil
Welcome to the forum.
As @KDJEM.1 said, you need to give some more details - Please see How to write your question to maximize your chances to find a solution for best results.
Pavel A.
May 30, 2025
PhumphathaiAuthorBest answer
Hello
Thank you.
