Error: failed to generate license for the current STM32 device
We are running the STM32 programmer in parallel via Test Stand, the programmer 1 is working fine, but the programmer 2 gives us an error message: “Error: failed to generate license for the current STM32 device”.
As the original setup, both programmers were running without any issue, the error just appeared in the last couple, which caused the FW programming step failed.  We tried to reseat the cable that connect to the programmer, reseat USB connect to the card reader.  Can’t solve the problem.
ST-LINK FW  : V3J15M7B5S1
Board: STLINK-V3SET
I hope any expert here can help me to solve this issue.  Thanks for your time.
TSLTAuthor
Adding version of the SW: STM32CubeProgrammer v2.19.0
Billy OWEN
Hi ​@TSLT
This post has been escalated to the ST Online Support Team for additional assistance.  We'll contact you directly.
Regards,
Billy
